Alles anzeigenIts in English because it gets to technical for me in German.
Its simple to solve.
It happens when your car is added in the app before delivery, then the pairing with the app goes wrong when you get the car if the car isn’t removed from my garage in the app first.
The solution is that you remove the car from my garage in the app and remove your profile in the car.
Then you starts over again with the pairing of the car and app.
You get into the car and turns it on and now you should have the blue screen with the QR CODE.
Then you open the app and selects add car to my garage and complete the pairing.
Now you should have all functions in climate control in the app.
It worked for me and many others in the danish BZ4X foren(Facebook groups)
I do it how you describe, but it don't have the complete climate control. Only temperature setting, not more.
Ja genau siehe Screenshot.
Zusätzlich kann ich jetzt die ladeplanung in der App vornehmen.
Ich habe übrigens direkt das Kontaktformular in der App verwendet um die Anfrage zu stellen.
So sollte es eigentlich bei allen aussehen.
Es scheint so als wäre es abhängig davon wer das Anliegen bei Toyota bearbeitet.
